Cooling Performance
Our micro-ATX test kit contains an Intel Core i7-875K CPU, which has been overclocked from 2.93GHz to 3.4GHz using a vcore of 1.175V and a CPU PLL of 1.86V. This is an admittedly modest overclock, but as some cases that we have trialled previously made the CPU run at a Delta T of nearly 60°C, it's reasonable for a micro-ATX case.
The CPU is cooled by a Gelid Tranquillo with a Noctua NF-S12B ULN 120mm fan. We run this at a consistent 12V speed, but it is a low-airflow fan, so it will highlight cases with poor cooling for the CPU. We also lock the fan speed on the graphics card to 30 percent in order to prevent the automatic speed control from interfering with the results, making them inconsistent.
We load the system using the Small FFTs CPU stress test in Prime95 and the Unigine Heaven DirectX 11 GPU benchmark. After at least 15 minutes, once temperatures have plateaued, we record the temperature of the hottest CPU core using Core Temp and of the GPU using GPU-Z. Having recorded the ambient temperature in front of the main air intake of each case, we're then able to calculate the delta T - the difference between the ambient temperature of our lab and the temperature of the hardware.
- CPU:
Intel Core i7-875K CPU overclocked to 3.4GHz (22 x 155MHz)
- Graphics Card: Sapphire Radeon HD 5770 1GB
- Motherboard: Gigabyte GA-H55M-UD2R
- RAM: 2GB PNY 1,600MHz DDR3
- Storage: Corsair Force GT 60GB SSD
- Heatsink: Gelid Tranquillo with a Noctua NF-S12B ULN fan
- Power Supply: Seasonic M12D SS-850EM
Using the ITX Upgrade Kit, we also fitted our Mini-ITX case testing system into the Enthoo Mini XL. This required moving the rear exhaust fan into the roof exhaust position. We then did thermal testing with just the mini-ITX system on, and then finally with both systems on and under load at the same time.
Our mini-ITX test kit includes:
- CPU: Intel Core i5-2500K overclocked to 4.3GHz using a vcore of 1.3V.
- Graphics card: GeForce GTX 570 1.3GB
- Motherboard: Asus P8Z77-I Deluxe
- RAM: 4GB Kingston DDR3 1600MHz memory
- PSU: Enermax Eco 82+ 620W PSU
- CPU cooler: Zalman CNPS 8900 low-profile cooler
While some cases can house larger coolers, for the results to be comparable, we needed to pick a cooler that was going to fit in as many cases as possible. We therefore opted for a low-profile cooler. This will give a good idea of how well the case is able to remove heat from the system - our primary concern in case testing - although you can probably expect to achieve better results by using a larger cooler if the case in question supports it.
The graphics card fan was locked at 70 per cent speed and the system was loaded using Prime95 and Unigine's Heaven benchmark. We used Realtemp and GPU-Z to monitor the temperatures, taking the maximum values when the readings had plateaued.
Micro-ATX Results
SilverStone Sugo SG10 (max speed)
SilverStone Sugo SG10 (min speed)
Fractal Design Arc Mini R2 (max speed; no HDD cage)
Corsair Obsidian 350D
Phanteks Enthoo Mini XL
Raijintek Aeneas
Phanteks Enthoo Mini XL (dual system)
Phanteks Enthoo EVOLV
Phanteks Enthoo Mini XL (no HDD cage)
Fractal Design Arc Mini R2 (min speed)
Deepcool Steam Castle (max speed)
Nanoxia Deep Silence 4 (max speed; no HDD cage)
Deepcool Steam Castle (min speed)
Aerocool Dead Silence Cube (mesh roof)
Fractal Design Node 804 (max speed)
Fractal Design Node 804 (medium speed)
Aerocool Dead Silence Cube (default roof)
Fractal Design Node 804 (min speed)
Nanoxia Deep Silence 4 (min speed)
°C, lower is better
Raijintek Aeneas
°C, lower is better
Mini-ITX Results
SilverStone Raven RVZ01
Silverstone Sugo SG08 (max speed)
BitFenix Prodigy
Silverstone Sugo SG08 (min speed)
Silverstone FT03-Mini
Fractal Design Node 304 (max speed)
Cooler Master Elite 130 Advanced
Lian Li PC-TU200
Thermaltake Core X1
Corsair Obsidian 250D
Lian Li PC-V360 (micro-ATX)
Lian Li PC-Q28
In-Win 901 (Zalman ZM-F2 92mm + Noctua NF-F12 120mm)
Lian Li PC-V358 (micro-ATX)
EVGA Hadron Air
BitFenix Phenom
Corsair Carbide Series Air 240 (micro-ATX)
Cooler Master Elite 120 Advanced
Xigmatek Nebula C
Antec ISK600
Raijintek Metis (w/ Asus GTX 970 Mini) (fan reversed)
Fractal Design Node 304 (min speed)
BitFenix Pandora (micro-ATX)
Parvum Systems X1.0 (Max speed)
Corsair Graphite 380T (max speed)
Parvum Systems X1.0 (7V)
Parvum Systems X1.0 (5V)
Corsair Graphite 380T (min speed)
SilverStone Precision PS09 (micro-ATX)
In-Win 901 (no fans)
20
30
40
50
60
70
80
°C, lower is better
Parvum Systems X1.0
BitFenix Prodigy
Xigmatek Nebula C
Thermaltake Core X1
Corsair Carbide Air 240 (micro-ATX)
Antec ISK600
EVGA Hadron Air
BitFenix Phenom
Lian Li PC-Q28
Lian Li PC-TU200
20
30
40
50
60
70
80
°C, lower is better
Read our
performance analysis on the next page.
